Integrating PeopleSoft Financials with Hyperion Tax Governance
PeopleSoft delivers a service for the integration between PeopleSoft Financials and Hyperion Tax Governance. Objects related to this service are delivered as inactive and must be activated in order to use this integration.
Prerequisites
Before implementing the integration between PeopleSoft Financials and Hyperion Tax Governance, the following technical and functional prerequisites must be met:
  • PeopleTools 8.51 or beyond.
    • Encrypted Security Assertion Markup Language (SAML) Token for Asynchronous Request/Response Web Service with wss10 policy
    • Process Status Notification
  • Hyperion Tax Governance Talleyrand Level Code and patch for this integration.
  • Oracle Web Services Manager (OWSM) 11g PS3.
  • Enable Single Sign-On (SSO) between Tax Governance and PeopleSoft using the Oracle Access Manager (OAM).
    See PeopleTools documentation: Security Administration, Implementing Single Signon, Implementing Oracle Access Manager as the PeopleSoft Single Signon Solution.
  • To call the web service for automated tasks, the run controls for each process must be predefined in the PeopleSoft system. To accomplish this, use the corresponding End User task.
