Journal Entry Approval
This section discusses the Journal Entry Approval workflow.
Description
| Information Type | Description |
Event Description |
Further Approval Required. |
Action Description |
Generates a worklist entry for the next user in the approval hierarchy. |
Notification Method |
Worklist. |
Workflow Objects
Approval Rule Set |
JOURNAL_ENTRY_APPROVAL |
Business Process |
Activity |
APPROVE_DENY_JOURNAL |
Role |
GL_ANALYST and SUPERVISOR |
