Journal Processing Options for a Business Unit
When you define a business unit, you can determine how the system processes a journal entry for that business unit. In General Ledger, you can specify these processing options at the business unit, ledger, or journal entry source level. Processing options defined for a ledger override those defined for a business unit. Options defined for a source override those defined for both a ledger and business unit.
Set journal options for the following types of errors:
| Term | Definition |
Journal Balance Errors |
When you define ledgers, specify them as balanced or unbalanced. Journal entries for balanced ledgers, such as an actuals ledger, must be in balance before posting. A journal balance error occurs when an unbalanced journal is targeted to a balanced ledger. |
Journal Edit Errors |
When you edit journals, General Ledger verifies that all ChartField values are valid as of the journal date. A journal edit error occurs if you enter an invalid ChartField value or combination on the journal lines. This error category also includes other line errors, such as a blank currency code or an invalid OpenItem reference value. |
Control Total Errors |
When you edit journals, any amounts entered on the Journal Entry Totals page are checked against the actual totals of the journal line amounts. |
Journal Amount Errors |
Foreign amounts and monetary amounts in a journal line must have the same sign. This error processing verifies that all amounts are either positive or negative. |
Journal Date Errors |
The journal date is validated against the open period. An error is generated if the journal date entered is not within the specified open period. |
