Limitations Using Edit Process during Import
It is important to understand that the edit process does not validate or support:
Suspense lines are not created even if it’s enabled in Ledgers for A Unit. The journal lines should be balanced if using the edit functionality. If journal lines are not balanced, then a error is displayed. If suspense line journals need to be imported, you must disable the edit option on the import process and use the online batch edit process.
