PeopleSoft Classic General Ledger WorkCenter
The PeopleSoft Classic General Ledger WorkCenter is a role-based central navigational component that is designed for users of the General Ledger application and related accounting functions.
The PeopleSoft Classic General Ledger WorkCenter is no longer supported as of FSCM Update Image 9.2.037. However, a fluid version of the General Ledger WorkCenter is available. See Understanding the PeopleSoft Fluid General Ledger WorkCenter and Using the PeopleSoft Fluid General Ledger WorkCenter.
For a general understanding of Workbenches and how to configure them, see Application Fundamentals: Understanding PeopleSoft Classic WorkCenters and Dashboards
General Ledger Dashboard
Like other components, the General Ledger Dashboard can be accessed directly (General Ledger, General Ledger Dashboard), or from the PeopleSoft Classic General Ledger WorkCenter. As delivered, the General Ledger Dashboard includes the Ledger Balances Analysis pagelet and the Account Reconciliation pagelet. You can personalize settings, use pivot grids, and filters to retrieve data for these pagelets within your WorkCenter.
For system administration setup information for WorkCenters and Dashboards, see Enterprise Components documentation: Setting Up WorkCenters and Dashboards.
For information about setting up PeopleTools options for the WorkCenter, see PeopleTools: Global Technology.
For more information about setting up pivot grids, see PeopleTools: Pivot Grid.
