Prerequisites
Before you set up integration between General Ledger and other PeopleSoft product applications that involve using IPs:
If you are integrating with PeopleSoft HCM products, you must select the HCM product by selecting
See Application Fundamentals: Setting Up Application-Specific Installation Options.
Read the Integration Broker topics thoroughly.
See PeopleTools Documentation: Integration Broker Service Operations Monitor
Review the Integration Broker topics to learn how to set up and manage the IB Gateway.
See PeopleTools Documentation: Integration Broker Administration, "Managing Integration Gateways"
