Spreadsheet Journal Imports Using Entry Events
To import and run spreadsheet journals containing entry events:
Select to load spreadsheet files that contain entry events.
Run the Spreadsheet Journal Import process.
This process sets the entry event status of header and each line with an entry event code to N(not generated). Consequently, you must run the Journal Edit process for these journals.
Related Topics
