Standard Journal Entries Using Entry Events
Standard journal entries are sometimes referred to as template or recurring journals. When you create standard journals, the system copies the entry event source lines, as well as any non entry event lines, and the entry event status of the header and lines is set to N (not generated). This means that you must run the Journal Edit process for these journals to regenerate the entry event lines.
