System Configuration for Journal Import
The system configurations for journal import should be in accordance with the expected concurrent users using the import utility.
Below are the recommended system configurations that should be followed for concurrent batch processing:
Max API Aware - Enter the maximum number of API-aware tasks that can run concurrently on the server. Set this value to a positive number, in accordance to the system capacity and environment configuration.
Max Concurrent - Enter the maximum number of processes belonging to the corresponding process category that can run concurrently on the server. This value should be a positive number, set as per your hardware capacity, environment configuration, and the expected concurrent batch processes.
Application Engine - Priority for this process has to be changed based on the value provided for the Max Concurrent field, and the expected concurrent run for this utility. Recommended priority is Medium or High.
GL_JRNL_UPLD process definition - For this process definition you have to provide the Max Concurrent value, to limit concurrent run of the program.
Process Scheduler’s Application Engine Server (PSAESRV) count has to be incremented in the Process Scheduler configuration file, based on the expected concurrent run of the process. After the increment, restart the Process Scheduler.
See the product documentation for PeopleTools: Creating Server Definitions and PeopleTools: Defining Process Definitions.
