Understanding Entry Events in General Ledger
Use entry events in PeopleSoft General Ledger to post additional debit and credit accounting entries. In addition, federal agencies can update budgetary as well as proprietary accounts in a single transaction or update the budgetary ledgers without posting to the actuals ledger.
This section lists prerequisites and discusses:
  • General Ledger entry event transactions.
  • Entry event source definitions, processes, steps and codes.
  • GLJE Entry Event process.
  • GLJEADJ Entry Event process.
  • Multibook ledgers using entry events.
  • Intra/Interunit journal entries using entry events.
  • Allocations using entry events.
  • Standard journal entries using entry events.
  • Separate debit and credit journal entries using entry events.
  • Flat file journal imports using entry events.
  • Spreadsheet journal imports using entry events.
  • Copy entry event journals.
  • Entry event journal errors.
