Understanding PeopleSoft Insights for General Ledger
PeopleSoft Insights is an analytical engine that provides visual reports (visualizations) in the form of charts, tables, graphs and so on. The visualizations are based on queries that retrieve data from the PeopleSoft Search Framework.
Dashboard administrators use PeopleSoft Insights and the underlying analytics engine to create both dashboards and visualizations, which are then attached to dashboards. The dashboard can contain multiple visualizations. The visualization and dashboard are objects in PeopleSoft Insights, which must be imported into the PeopleSoft application.
Typically, a PeopleSoft user who has the Search Administrator role performs these tasks:
  • Deploys dashboards.
  • Configures dashboards as tiles or related information.
  • Specifies user privileges for the dashboard.
    End users access dashboards based on user privileges.
  • Imports dashboards.
Oracle recommends that you do not modify or edit a delivered dashboard or visualization. You may copy a delivered visualization and then modify it as per your business requirements.
For more information, see PeopleTools Search Technology, “Working with Insights Dashboards for PeopleSoft Application Data", Understanding Application Data and Insights Dashboards.
For more information about PeopleSoft Search Framework, see Understanding PeopleSoft Insights Using PeopleSoft Search Framework.
