Using Journal Generator with PeopleSoft Applications
PeopleSoft feeder applications typically generate accounting or voucher lines from transaction data that you enter in the particular application. PeopleSoft posts these accounting lines to an accounting entry table. Journal Generator processes data in the accounting entry table to create journals in General Ledger and optionally edit and post them to the ledgers.
You can create journal entries and optionally post them from any of these PeopleSoft applications:
PeopleSoft Application Name PeopleSoft Application Name (continued)
Asset Management
Promotion Management
Accounts Payable
Purchasing
Accounts Receivable
Order Management
Billing
Treasury
Contracts
Enterprise Learning Management (ELM)
Expenses
Learning Solutions − Contributor Relations
Grants
Learning Solutions − Student Financials
Inventory
HCM — Global Payroll
Project Costing
HCM — North America Payroll
PeopleSoft ELM, HCM, and Learning Solutions are run in different databases from General Ledger. Their accounting entries are transferred using IPs and then processed by Journal Generator.
