Using Oracle Business Intelligence Publisher Reporting to Support ChartField Configuration
Oracle Business Intelligence Publisher (BI Publisher) is an enterprise reporting solution that streamlines report and form generation. In order to provide a more robust and complete reporting functionality, Oracle's PeopleSoft applications offer many existing reports in the BI Publisher (formerly XMLP) format. Reports created using BI Publisher for PeopleSoft require no manual changes to support configured ChartFields. The BI Publisher format also provides flexibility for adopting future technology with smoother transitions. For information about the existing reports that are available in BI Publisher format, refer to the Reports listing for each product. Oracle BI Publisher technology is accessible from PeopleTools PS Query and all PeopleTools applications. This technology enables PeopleSoft to deliver BI Publisher reports that do not require manual changes to support ChartField configuration.
The following is a list of BI Publisher General Ledger reports:
SpeedTypes report: FSX0007 BI Publisher report.
Valid Department Codes report: FSX0011 BI Publisher report.
Valid Product Codes report: FSX0012 BI Publisher report.
Valid Project IDs report: FSX0013 BI Publisher report.
Ledger Translation Errors: FSX5101 BI Publisher report.
Summary Ledger Definition: GLX1000 BI Publisher report.
Ledger Code: GLX1001 BI Publisher report.
Summary Calendars: GLX4001 BI Publisher report.
Combination Edit Group: GLX4003 BI Publisher report.
Journal Entry Template: GLX4007 BI Publisher report.
Valid Journal Class: GLX4008 BI Publisher report.
ADB Processes: GLX5501 BI Publisher report.
Allocation Group Definition: GLX6001 BI Publisher report.
Journal Entry Detail: GLX7501 BI Publisher report.
Journal Entry Detail (separate debit and credit): GLX7502 BI Publisher report.
