Tax Determination Output Parameters
The Tax Determination process returns the following values, using rowsets for online processing, and temporary tables for batch processing:
| Field | Notes (if applicable) |
Business Unit Tax and Customs Duty Applicability (online processing only) |
Applicable only when the Tax Default Option is defined as header. |
Trading Partner Tax and Customs Duty Applicability (online processing only) |
Organization SetID |
Organization Code |
Organization Tax Location Code |
Tax Transaction Type |
If the calling application passes a value to the function in this field, the process does not overwrite the value. Valid values are: DEB: direct export with bond. DEWB: direct export without bond. DIMP: direct import. DOM: domestic. IUT: InterUnit transfer. LEB: local export with bond. LEWB: local export without bond. LIMP: local import. |
Trading Partner Tax Category - Customs Duty |
If the calling application passes a value to the function in this field, the process does not overwrite the value. |
Item/Product Kit Tax Item Type |
Valid values are: C: capital goods. R: raw materials. F: finished goods. |
Tax Calculation Code |
Customs Duty Applicability Flag |
Indicates whether the row is customs duty applicable. |
Customs Duty Calculation Code |
Use Assessable Value flag |
The system calculates excise duty based on the assessable value. When no sales value is applied to a shipment, excise duty may still be applicable based on the value of the items. Assessable value is based on customer category, item category, or item ID. |
Assessable Value |
The assessable value in the currency associated with the tax location. |
Conversion Rate |
Conversion rate between standard unit of measure and excise unit of measure. |
Service Tax Flag |
Tax Location Reporting Currency |
