Project Data Deletion
The Projects Delete Utility page provides a means of deleting projects, activities, and resources that you created by mistake. The system purges transactions from the Project Resource table (PROJ_RESOURCE) without purging the corresponding projects-related data from the feeder system applications (for example, PeopleSoft Payables).
Instructions on deleting projects appear in the PeopleSoft Project Costing documentation.
