Searching for Award, Project, and Personnel Data in the Grants Portal
The Grants Portal enables you to search for and filter award, project, and personnel data using specialized search pages designed specifically for the Grants Portal. You access these search pages using the Set Search Criteria link, available on select Grants Portal pages:
grantsportalsearch_setsearchcriteria_link
The Set Search Criteria link is available on the following Grants Portal pages:
  • Award Summary
  • Project Summary
  • Personnel Cost Summary
Creating Your Own Search
To search for award, project, and personnel cost data using your own search parameters:
  1. Click the Set Search Criteria link on the Award Summary, Project Summary, or Personnel Cost Summary page.
  2. Enter your search criteria.
    Each search page has its own set of fields you can use to enter your search criteria.
    While you can use as many of these fields as you want, at minimum you must enter search criteria for the Business Unit field.
  3. Click the Search button.
  4. (Optional) Save your unique set of search criteria by entering a name for your search in the User Saved Search field and clicking the Save Search Criteria link.
  5. (Optional) Select the Public option to make your saved search available to other users.
    A public search can be altered or deleted only by the person who created it.
    If you do not select the Public option, your saved search will stay private and only you can access it.
    All existing saved searches will be made public and users will not be able to change these searches to private. However, users will be able to alter and delete these searches.
Using a User Saved Search
To search for award, project, and personnel cost data using existing saved search parameters:
  2. Click the Look up User Saved Search icon.
    The results list displays any saved searches you created plus public saved searches by other users.
  3. Select a saved search from the results list.
  4. Click the Search button.
