Setting up the Fulfillment Engine EIPs
There are five inbound service operations used by the fulfillment engine. PeopleSoft delivers the service operations in PeopleSoft Integration Broker with a default status of Inactive. You must activate each service operation before attempting to send or receive data from a third-party source. The following setup is required to use the Fulfillment Engine EIPs:
  1. Setup within the PeopleSoft Inventory application:
    Set up the fulfillment engine processing options using the Setup Fulfillment - Fulfillment Engine Options component.
  2. Setup within PeopleSoft Integration Broker and Enterprise Components:
    Use the information in the table below and refer to the setup instruction in the PeopleSoft Supply Chain Management Integrations, "Implementing Integrations" topic, Setting Up Service Operations section.
Service Operation Direction and Type Handlers Chunking Available? Integrates With
INVENTORY_CREATE_STOCK_REQUEST
Inbound
Asynchronous
InventoryCreateStockRequest
No
Third-party system
INVENTORY_RESERVATION
Inbound
Asynchronous
InventoryReservation
No
Third-party system
INVENTORY_PICK_CONFIRM
Inbound
Asynchronous
InventoryPickConfirm
No
Third-party system
INVENTORY_FRONT_END_SHIPPING
Inbound
Asynchronous
InventoryFrontEndShipping
No
Third-party system
INVENTORY_SHIPPING
Inbound
Asynchronous
InventoryShipping
No
Third-party system
