Mapping Enterprise Data Flow
You need to determine the flow of data into and out of PeopleSoft Lease Administration. Mapping which applications integrate with PeopleSoft Lease Administration and how to carry out that integration helps you with setup decisions.
Here are some questions to help with this mapping:
What applications which integrate with PeopleSoft Lease Administration do you want to utilize?
Are these applications currently implemented?
If not, when are they scheduled for implementation?
Both PeopleSoft General Ledger and PeopleSoft Asset Management need to be implemented prior to or at the same time as the implementation of PeopleSoft Lease Administration. Additionally, PeopleSoft Payables must be used for processing of transactions to the landlords, and the Transaction Billing Processor and PeopleSoft Billing must be used for processing transactions to subtenants.
What do you want to track in your PeopleSoft Lease Administration system?
Do you want to create projects or assets from acquired sites?
