Condition-Based Monitoring System Setup Considerations
Web Services are used to enable external condition-based monitoring systems to notify a condition-based maintenance (CBM) coordinator in PeopleSoft Maintenance Management that an asset requires maintenance or repair using a work order based on its condition. The external systems send the alert to PeopleSoft Maintenance Management. When the alert is saved, PeopleSoft Maintenance Management sends back the alert identification to the external systems.
If an error occurs in PeopleSoft Maintenance Management, Integration Broker sends the error back to the CBM system through Web Services that the:
Asset business unit is not valid.
Asset ID is not valid.
Asset level is not valid.
Duplicate alert.
Request Message: WM_ALERT_REQ
urn:oracle.enterprise.fscm.data.cbm.AlertRequest.V1
Response message: WM_ALERT_RES
urn:oracle.enterprise.fscm.data.cbm.AlertResponse.V1
Service Operation:WM_ALERT_ADD
Synchronous Operation
Service: WM_ALERT
urn:oracle.enterprise.fscm.service.cbm.Alert
See documentation PeopleSoft PeopleTools Integration Broker
