PeopleSoft Asset Management Setup Considerations
In order to maintain assets using a service request or work order, you must set up assets in PeopleSoft Asset Management's asset repository prior to setting up PeopleSoft Maintenance Management. In addition to the setup required for financial PeopleSoft Asset Management, PeopleSoft Maintenance Management recommends that your PeopleSoft Asset Management setup include:
Installation options.
Asset locations.
Asset area –
Asset type, asset subtype, manufacturer ID, and model.
The only place that the manufacturer ID and model are associated with the asset type and subtype is in the equipment parts list (EPL) in PeopleSoft Asset Management. You set the manufacturer ID and model up inYou associate them with an asset in PeopleSoft Maintenance Management task and template setup.
Chargeback information at the asset level.
Component changeout rule definitions at the Asset Management business unit, asset type, asset subtype, and asset levels.
Maintenance types
Users define maintenance types in PeopleSoft Asset Management and associate them with an asset type and subtype in PeopleSoft Maintenance Management.
EPL. (This is optional and is located at
Insurance types
Standard warranties
Warranty templates
Interunit transfer definition -
Meter types
Assets set up as tools -
See Asset Lifecycle Management Fundamentals: Understanding the PeopleSoft Asset Management Lifecycle.
