PeopleSoft Maintenance Management Reports: A to Z
This table list Oracle's PeopleSoft Maintenance Management reports, sorted alphanumerically by report ID. The reports listed are all BI Publisher reports. If you need more information about a report, refer to the report details at the end of this troubleshooting section.
| Report ID and Report Name | Description | Navigation | Run Control Page |
WM10001 Work Order Task Detail Report |
Lists work order task detail information for each work order task. The report displays different sections depending on the selected reporting options. These reporting options are: Labor Assignment Report, Material Assignment Report, Procurement/On-hand Report, Tool Assignment Report, Instruction Report, Check List Report, Work Order Notes Report, Task Notes Report, Equipment Parts List and Attachments. When there is no information available for the selected reporting option for the selected tasks, the report does not include the corresponding report section. |
WM_RPT_OPTNS |
WM10001 Work Order Task Detail Report (run from run control page) |
Lists work order task detail information for work order tasks that meet the selection criteria on the Work Order Task Detail Report Options run control page. The report displays different sections depending on the selected reporting options. These reporting options are: Labor Assignment Report, Material Assignment Report, Procurement/On-hand Report, Tool Assignment Report, Instruction Report, Check List Report, Work Order Notes Report, Task Notes Report, Equipment Parts List and Attachments. When there is no information available for the selected reporting option for the selected tasks, the report does not include the corresponding report section. |
WM_WO_RPT |
WM11000 Work Order Task Material Readiness Report |
Describes the ongoing availability of needed inventory materials and other non-inventory/procured material items and services. The report indicates, for scheduled work order tasks selected over an (expected) relatively tight analysis date range, whether the tasks are material ready or not, and with the optional identification of any item exceptions that are not ready accompanied by an explanatory reason. |
Maintenance Management, Inquiries and Reports, Material Readiness Report |
WM_WO_MATREADY_RPT |
WM20000 Preventive Maintenance Report |
List all preventive maintenance (PM) schedule transactions that match the search criteria on the Preventive Maintenance Inquiry page. The report shows the maintenance percentage for each PM schedule, the next due reading, and the due date. The report shows work order information if a work order exists for the PM schedule transaction. |
Maintenance Management, Preventive Maintenance, View Preventive Maintenance, Preventive Maintenance Inquiry Click Print on the Preventive Maintenance Inquiry page. |
WM_PM |
WM20001 Preventive Maintenance by Process Instance Report |
Lists all PM schedule transactions that were processed in a specific process instance of the Preventive Maintenance process (WM_PM) and shows the maintenance percentage. The report displays the due reading and due date, the asset description, tag number, and serial ID fields. It also includes work order information if the process created a work order. |
WM_PM_RUN_SEL |
WM20002 PM Projection Report |
Displays projection information, which includes the work order and Asset Management business units, asset, asset location, type, asset description, tag number, serial ID, due date, SetID, loop, and projection ID after running the Projection process. |
Maintenance Management, Preventive Maintenance, Run Projection |
WM_PM_RUN_SEL |
WM30000 Crew Availability Report |
Provides information on the crew's base capacity, adjusted capacity hours, target load, confirmed scheduled hours, scheduled hours, variance between the confirmed scheduled hours and scheduled hours and the percentage of scheduled hours, availability, and target load by Business Unit, Shop, Crew, period and lead craft. |
Maintenance Management, Inquiries and Reports, Crew Schedule Reports, Crew Capacity Report |
WM_CREW_CAPACI_REQ |
WM30001 Crew Schedule (and Assignment) Report |
Describes the load of work by craft within each crew and includes the work order, task, status, priority, target equipment and the hours assigned to a craft in the specified schedule period by business unit and shop. It also describes employee task assignments, scheduled start and end dates and times, and actual hours worked. It also shows the employee ID, name and scheduled start/end date time when include detail option is selected when requesting the report to run. If the Include Detail check box is not selected, the report will not display crew assignments. |
Maintenance Management, Inquiries and Reports, Crew Schedule Reports, Crew Schedule & Assignment Rpt |
WM_CREW_SCHED_REQ |
WM30003 Maintenance Schedule Completion Report |
. The report show the completion status of all the work order tasks that were scheduled for the crew to complete in the schedule periods and all unplanned/ emergency tasks assigned to crew during those periods. This report helps users measure how well the crews comply with the schedule for the schedule period. Users should be able to determine the following: 1) Unscheduled/emergency work that are completed within the period— For example, when completed scheduled hours are zero and completed hours are not zero. These tasks are identified by the Unplanned Column on the report. 2) Completed Scheduled Work - For example, when both completed scheduled hours and completed hours are greater than zero. 3) Scheduled Work that is not completed and becomes carryover work (These tasks are indicated by the Carryover column on the report). |
Maintenance Management, Inquiries and Reports, Crew Schedule Reports, Crew Schedule Completion Rpt |
WM_SCHED_RPT_REQ |
WM30004 Unscheduled Report |
Lists all the work orders currently not scheduled to crews. It is used for review during the scheduling meeting and lists work orders by business unit, shop, and preferred crew. |
Maintenance Management, Inquiries and Reports, Crew Schedule Reports, Crew Unscheduled Work Report |
WM_UNSCHEDULED_REQ |
WM30005 Crew Carryover Work Report |
Lists the crew scheduled work orders not yet completed by the targeted date, which should be rescheduled / carried over to the next period. It displays the assigned craft, schedule dates, and carryover hours by business unit, shop, and crew. |
Maintenance Management, Inquiries and Reports, Crew Schedule Reports, Crew Carry Over Work Report |
WM_CARRYOVER_REQ |
WM50000 Warranty Claim |
Shows the current warranty claim information. It displays the claim sender information, the supplier contact information, a list of failure and cost details, and the supporting meter readings. |
Click Print on the Claim Summary page. |
WM_CLAIM_HDR |
