PeopleSoft Maintenance Management Work Order Creation
After setting up PeopleSoft Maintenance Management and other products that integrate with PeopleSoft Maintenance Management, you are ready to create work orders. You can use the following methods to create work orders.
  • Work order creation from Service Request components.
  • Work order creation from PeopleSoft CRM Help Desk, and third-party help desk applications.
  • Work order creation from PeopleSoft Project Costing.
  • Work order creation from PeopleSoft Program Management.
  • Work order creation using the Express Work Order component.
  • Work order creation using the Preventive Maintenance and Preventive Maintenance Projection processes.
  • Work order creation using the CBM Alert component.
  • Work order creation for an Asset based on an ESRI map location.
    The integration with ESRI ARCGIS (Geographic Information System) and Asset Lifecycle Management is no longer supported as of FSCM Update Image 9.2.055.
  • Work order creation using the Work Order component.
