Revising the Delivered PM schedule Approval Workflow
  • Modify the approval process definition.
  • Define approval criteria.
  • Define approval paths.
  • Define approval steps.
  • Authorize approvers.
  • Modify approval notification options.
  • Define generic notification templates.
  • Maintain user list definitions.
