Setup Process Definition Page
Use the Setup Process Definition page for the WM_WORK_ORDER approval process
Navigation:
This page is described in the Defining Approval Workflow Processes section of the Enterprise Components: PeopleSoft Approval Framework .
These are fields on the Setup Process Definitions page that either do not apply to the WM_WORK_ORDER approval process, or if they apply to the WM_WORK_ORDER approval process, they require specific field values.
The Take Action on Line Completion check box does not appear in the Definition Options group box, because the WM_WORK_ORDER approval process only affects the header (work order) level.
Header is the default value for the Level field because the WM_WORK_ORDER workflow process only requires approval at the header (work order) level. You cannot change this value.
Application Class criteria does not apply to the WM_WORK_ORDER approval process.
When you click the Criteria link in the Paths group box or Criteria icon in the Steps group box on the Setup Process Definitions page to access the Criteria Definitions page with a Criteria Type of User Entered, the Record field value should be WM_WO_HDR for the WM_WORK_ORDER approval process.
