Shared Products Setup Considerations
PeopleSoft Maintenance Management shares the functionality of specific PeopleSoft products instead of integrating with these products. This means that you are not required to install these products to benefit from their functionality. However, since these products share certain functionality, you must set up common components that are used by each product.
This section discusses:
PeopleSoft Expenses setup considerations.
PeopleSoft Resource Management setup considerations.
PeopleSoft HRMS setup considerations.
