Understanding Resource Scheduling
Once you create a work order and at least one work order task, you have the option of specifying resource requirements and assigning and scheduling these resources for each work order task.
This section discusses:
Labor resource scheduling.
Tool resource scheduling.
Labor and tool resource matching.
Labor resource assignment approval workflow.
Move labor or tool resources to Purchase/On-Hand.
Inventory resource scheduling.
Inventory item availability.
Procurement of material, tool, and labor resources using the Purchase/On-Hand Schedules grid.
The Work Order Workbench.
