Understanding the Work Order Approval Workflow Architecture
To ensure that all work orders have proper authorization, the system is able to dynamically route work orders to the appropriate people for approval using business rules that you establish for your organization, based on your particular business needs. This section discusses:
  • Terminology.
  • Architecture.
  • Work order approval workflow modifications.
