Work Order Creation for an Asset from an ESRI Map Location
You can create a work order from an asset location on an ESRI map. You click a Map It button to access the ESRI map for a single asset in PeopleSoft Asset Management from these pages:
The integration with ESRI ARCGIS (Geographic Information System) and Asset Lifecycle Management is no longer supported as of FSCM Update Image 9.2.055.
Location/Comments/Attributes page in the Basic Add component. (Asset Management, Asset Transactions, Owned Assets, Basic Add.)
Location group box on the Asset Information page in the Define Asset Operational Information component. (Asset Management, Transactions, Owned Assets, Define Asset Operational Information.)
You click the Map Selected Assets button to access the ESRI map for a single or multiple assets selected on the Asset Map Dashboard in PeopleSoft Asset Management. Once you access a map, the AM business unit and asset ID display as a marker for the selected assets. When you click on the marker, these details about the asset display:
AM Business Unit (in label)
Asset ID (in label)
Asset Type
Asset Sub-Type
Asset Description
Asset Status
Asset Location
Asset Area.
Depending on the page from which you accessed the map, specific links appear on the sub page:
When you access the map from the Location/Comments/Attributes page or the Location group box on the Asset Information page, a link to create and Express Work Order appears on the sub page.
When you access the map from the Asset Map Dashboard, two links appear on the sub page.
One link enables you to create an express work order, and the second link enables you to drill down to asset.
PeopleSoft does not automatically update the latitude or longitude in the location definition. These must be entered manually.
