Work Order Creation from PeopleSoft Project Costing
You can create a work order directly from PeopleSoft Project Costing for any work orders that you want to associate with a Project Costing-managed project. Once you create the work order, you can create work order tasks, define resource requirements, schedule resources, and execute the work order the same as any other work order. However, all accounting rules are set up in the PeopleSoft Project Costing system and work orders that are associated with a Project Costing-managed project are not affected by the work order close process.
See PeopleSoft Project Costing: Creating Work Orders and Work Order-Managed Projects in PeopleSoft Project Costing.
