Manufacturing Execution System Integration
If you're using PeopleSoft Manufacturing with a Manufacturing Execution System (MES), the system publishes messages for the MES when you add or modify production IDs or production schedules. The system publishes production order messages when you:
  • Change the production status of a production ID or production schedule to Released.
  • Modify a released production ID or production schedule.
  • Change the production status of a production ID or production schedule from Released to an earlier status.
  • Change a component list or operation list.
  • Change an output list.
  • Split a production ID.
When the system publishes a production order for the MES:
  • The system includes the component list and operation list, with attachments and documents, as well as the output list for the production ID or production schedule.
  • You release production IDs or production schedules in either PeopleSoft Manufacturing or the MES.
  • You perform detailed production scheduling, production monitoring, and reporting in the MES.
