PeopleSoft Manufacturing Implementation
PeopleSoft Setup Manager enables you to generate a list of setup tasks for the organization based on the features that you are implementing. The setup tasks include the components that you must set up, listed in the order in which you must enter data into the component tables, and links to the corresponding documentation.
PeopleSoft Manufacturing also provides component interfaces to help you load data from the existing system into PeopleSoft Manufacturing tables. Use the Excel to Component Interface utility with the component interfaces to populate the tables.
This table lists all of the components that have component interfaces:
Component Component Interface Reference
Item Groups
INV_ITEM_GROUPS_CI
See PeopleSoft Managing Items: Setting Definitions for Item Control Values.
Ultimate Use Code
SUT_USE_CI
See Application Fundamentals: Defining Additional Common Information.
Item Load from Excel
IN_MST_ITM_XLS
See PeopleSoft Managing Items: Using the Excel-to-Component-Interface Utility.
Sales and Use Tax Authorities
TAX_AUTHORITY_CI
See Application Fundamentals: Defining Sales and Use Tax Authorities and Codes.
Sales and Use Tax Codes
TAX_CODE_CI
Distribution Type
CM_DISTR_TYPE_CI
See PeopleSoft Cost Management: Distribution Type Page.
Automatic Serial Numbers
AUTO_SERIAL_NUM_CI
See PeopleSoft Managing Items: Defining Items at the SetID Level
Transfer Attributes
UNIT_TRANSFER_DEF_CI
See PeopleSoft Inventory: Understanding Stock Transfers Between Business Units
Transfer Attributes Defaults
TRANS_UNIT_INV_CI
Production Conversion Codes
CE_CONCODE_CI
See PeopleSoft Cost Management: Understanding the Manufacturing Standard Cost Foundation
Costing Conversion Overhead Rates
CE_CONV_OH_RATE_CI
Conversion Rates
CE_CONV_RATE_CI
Forecasted Purchase Costs
CE_FCST_CI
Additional Item Costs
CE_ITEMEXP_CI
Conversion Overhead Codes
CE_OHCODE_CODE_CI
Bill of Material Privileges
EN_IC_BOM_PRIV_CI
See Understanding BOM Maintenance
Item Price Markup
MARKUP_PCT_INV_CI
See PeopleSoft Cost Management: Understanding Interunit Transfers
Production Replenish Locations
REPL_LOCATIONS_CI
See Understanding Component Issue Methods
Item Transfer Price
STD_PRICE_INV_CI
Floor and Ceiling Costs
CM_VALUE_REF_PGRP_CI
See PeopleSoft Cost Management: Generating Reports of Financial Transactions.
Fixed Picking Locations
FIXED_PICK_BINS_CI
See PeopleSoft Inventory: Assigning Fixed Picking Locations.
Crew Actual Costs
CE_CREW_ACTCOST_CI
See PeopleSoft Cost Management: Crew Actual Cost Page.
PeopleSoft Events and Notifications Framework
As your organization processes the continuous stream of transactions within your PeopleSoft system, the events and notifications framework enables you to monitor the transaction flow and alert your organization to any errors, changes, and stalled transactions. The messages generated by the events and notifications framework can notify you of the problem, give you a detailed description of the issue, and provide a link to the PeopleSoft page where you can resolve it. One of the ways to use the events and notifications framework is to create PeopleSoft Queries on one or more PeopleSoft tables, add the alert using the Alert Setup component, and then complete the alert setup steps. This method enables you to monitor data within a PeopleSoft table; for example, searching for stalled transactions, instead of looking at the results of a PeopleSoft process. When the Alerts process (EOEN_ALERT) is run, the PeopleSoft table is queried and the alert messages can be generated. These messages can be routed to the appropriate person (PeopleSoft user or non-PeopleSoft user) using an email, a PeopleSoft worklist entry, an XML message, or the PeopleSoft Notification Dashboard.
For the PeopleSoft Manufacturing application, sample data includes the following PeopleSoft queries that have been setup to work with the events and notifications framework. These queries may require minor modifications to work in your environment. You can also copy and alter these queries to create new alert messages.
Query Process Name Process Category Description
MG_BCT_ERRORS
MG_ALERTS
MG_BCT_ERRORS
Query the BCT staging tables and generate alert messages for the following manufacturing transactions that are in error:
  • 210 Production Pick Plan
  • 220 Completion/Scrap
  • 225 Edit Issue Components
  • 230 Production Kit Issue/Return
  • 240 Actual Hours
  • 250 MFG Replenishment Request
  • 400 Serial Genealogy
MG_BCT_UNPROCESS
MG_ALERTS
MG_BCT_UNPROCESS
Query the BCT staging tables and generate alert messages for the following manufacturing transactions that have not been processed for more than 120 minutes:
  • 240 Actual Hours
Note: The number of minutes can be changed by modifying the query.
MG_COMP_OVERISSUE
MG_ALERTS
ISS_REPL_COMP_OVERISSUE
Generates alert messages for production IDs and production schedules:
  • With a status of In Process.
  • With component issue method of Issue or Replenish.
  • Any component has an issue quantity greater than 110 percent of the scheduled quantity.
Note: The percentage can be changed by modifying the query.
MG_KIT_COMP_OVERISSUE
MG_ALERTS
KIT_COMP_OVERISSUE
  • With component issue method of Kit.
MG_LATE_PRODUCTION
MG_ALERTS
LATE_PRODUCTION
  • With a status of Released or In Process.
  • Completed quantity is less than 95 percent of the scheduled quantity and are past due.
See PeopleSoft Documentation: Approval Framework
Other Sources of Information
In the planning phase of your implementation, take advantage of all PeopleSoft sources of information, including the installation guides, table-loading sequences, and data models. A complete list of these resources appears in the preface in the PeopleSoft Application Fundamentals Documentation, with information about where to find the most current version of each.
See the product documentation for PeopleTools: Setup Managerand PeopleTools: Component Interfaces
