PeopleSoft Manufacturing Reports: General Description
This table lists the PeopleSoft Manufacturing reports. All the reports that are listed are SQR reports. If you need more information about these reports, refer to the report details at the end of this section.
For samples of these reports, select Report Samples.
Report ID and Report Name Description Navigation Run Control Page
ENS1000
BOM Report
Lists the components on either manufacturing or engineering BOMs.
  • Manufacturing Definitions, and then BOMs and Revisions, and then Reports, and then Create a Bill of Material
  • Engineering, and then BOMs and Revisions, and then Reports, and then Bills of Material, and then EBOM Report
EN_BOM_REPORT
ENS1001
Routing Report
Lists the routing information for manufacturing or engineering routings.
  • Manufacturing Definitions, and then Resources and Routings, and then Routings, and then Routing Report
  • Engineering, and then Routings, and then Engineering Routing Report, and then Routing Report
RUN_ENS1001
ENS1002
Compare Routings Report
Lists the differences between two manufacturing routings, two engineering routings, or one manufacturing routing and one engineering routing. Comparisons can also based the same item with different routing codes.
  • Manufacturing Definitions, and then Resources and Routings, and then Routings, and then Routing Comparison Report, and then Routing Compare Report
  • Engineering, and then Routings, and then Eng Routing Comparison Report, and then Routing Compare Report
RUN_ENS1002
ENS1003
Master Routing Where Used Report
Lists all items that reference another item as its master routing along with production data. This report is used in both Manufacturing and Engineering.
  • Manufacturing Definitions, and then Resources and Routings, and then Routings, and then Master Rtg Where Used Report
  • Engineering, and then Routings, and then Eng Master Routing Where Used, and then Master Rtg Where Used Report
RUN_ENS1003
ENS1004
Resources Where Used Report
Lists where resources are used on work centers, tasks, routings, and in production.
Manufacturing Definitions, and then Resources and Routings, and then Resources Where Used Report
RUN_ENS1004
ENS1005
Compare BOMs Report
Lists the differences between a manufacturing and an engineering BOM, or two engineering BOMs.
  • Manufacturing Definitions, and then BOMs and Revisions, and then Reports, and then BOM Comparison Report, and then BOM Compare Report
  • Engineering, and then BOMs and Revisions, and then Reports, and then EBOM Comparison, and then EBOM Compare Report
EN_BOM_COMP_REPORT
ENS1006
Work Centers Where Used Report
Lists the tasks, routings, and production associated with either a selected work center or a range of work centers within a particular business unit.
Manufacturing Definitions, and then Tasks and Work Centers, and then Work Centers Where Used Report
RUN_ENS1006
ENS1007
Tasks Where Used Report
Lists the routings and production associated with either a selected task or a range of tasks within a particular business unit.
Manufacturing Definitions, and then Tasks and Work Centers, and then Tasks Where Used Report
RUN_ENS1006B
ENS1010
BOM Cost Report
Lists the component costs on either manufacturing or engineering BOMs.
  • Manufacturing Definitions, and then BOMs and Revisions, and then Reports, and then Generate Costed BOM Report, and then BOM Costed Report
  • Engineering, and then BOMs and Revisions, and then Reports, and then EBOM Costed Report
EN_BOM_COST_REPORT
ENS2000
Item Where Used Report
Lists all the BOMs on which an item appears either as a component or a substitute for a component. You'll find this information useful when you want to analyze the impact component changes can have on all existing BOMs.
  • Manufacturing Definitions, and then BOMs and Revisions, and then Reports, and then Item Where Used
  • Engineering, and then BOMs and Revisions, and then Reports, and then Item Where Used
EN_WHEREUSED_RPT
SF_MATRDY
Material Readiness Report
Determines the material readiness of a production run by checking the available quantity of component materials.
See Running the Material Readiness Report.
Production Control, and then Process Production, and then Release Production, and then Material Readiness Report
RUN_SF_MTLRDY
RUN_SF_MTLRDY_SD
SFS1100
Production Close Process Report
Lists closed production schedules or production IDs, and details the variances incurred. Combine sort options to narrow down the production close information that is reported. For example, close only those production IDs within a selected production area for a single item. Use the Report Only Mode to view the production that can and can't be closed as well as the variances that can be generated as a result of an accounting close.
Production Control, and then Close and Analyze Production, and then Close Production
RUN_SFS1100
SFS1200
Production Reopen Process Report
Lists the before and after status of the production ID or area/item that needs to be reopened. Combining numerous sort options assists in narrowing down the production reopen information that is reported. For example, reopen production only for those production IDs within a selected production area for a single item. Use the Report Only Mode to provide a preview of the financial impact of reopening production without creating reversing entries.
Production Control, and then Close and Analyze Production, and then Reopen Production
RUN_SFS1200
SFS1500
Production Variance Report
Lists variances for production IDs or production schedules for a specified production due date/shift and above a minimum monetary amount. Variances include configuration, usage, component yield, lot size, routing process, rework, teardown, production mix variance, and outside processing.
Production Control, and then Close and Analyze Production, and then Production Variance Report
RUN_SFS1500
SFS1600
Potential Production Variance Report
Lists potential production variances that exist in production above a monetary amount, prior to closing for accounting production IDs and schedules. The report can be generated when in a production status of in process, pending complete, complete, and closed for labor. Variances include configuration, usage, component yield, lot size, routing process, rework, teardown, production mix variance, and outside processing.
Production Control, and then Close and Analyze Production, and then Potential Prdn Variance Report
RUN_SFS1600
SFS2001
Material Shortage Report
Lists production shortages as well as surplus inventory. Report options include a summary report or a report that ignores surplus quantities.
Production Control, and then Close and Analyze Production, and then Shortage Report
RUN_SFS2001
SFS2002
Dispatch List
Lists production ID or production schedule information, including operation and task details for each work center or range of work centers. Use this document to review the type and quantity of production that will be occurring at a particular work center or range of work centers for a specified date or range of dates. Selects production information by production start date or due date, or lists production that is past due. Additional report information includes component information for each work center/operation, operation start and due dates/times, subcontracted operation information, and production and operation level text.
Production Control, and then Process Production, and then Release Production, and then Print Dispatch List
RUN_SFS2002
SFS2003
Production Documents
Lists the component list, operation list, and work center, resource, and schedule information for a particular production ID. Print production documents for production IDs with a production document status of Ready to Print, reprint production documents, or print production documents for the specified production IDs regardless of the production document print status.
Production Control, and then Process Production, and then Release Production, and then Print Production Documents
RUN_SFS2003
SFS2004
Production Report
Lists all scheduled production for a specified range of actual start dates, production statuses, and production IDs and production schedules. Sort by actual due date, item ID, production area, production due date, or production start date.
Production Control, and then Define Production, and then Reports, and then Production Report
RUN_SFS2004
SFS2005
Efficiency and Utilization Report
Lists variances and utilization by operation, work center, production ID, and production area/item for both labor and machine. Report earned and actual labor by work center with or without the production ID or production schedule detail.
Production Control, and then Close and Analyze Production, and then Efficiency and Util Rpt
RUN_SFS2005
SFS2006
Component Where Used in Prdn Report
Lists the production IDs or production schedules where specified components are used in production. This report can be sorted by item ID, production due shift, production start date, or production ID. Also lists substitute information for the component, and can include production with a status of Firmed, Released, In Process, Pending Complete, Complete, Closed for Labor, and Closed to Accounting.
Production Control, and then Define Production, and then Reports, and then Component Where Used Report
RUN_SFS2006
SFS2007
Production Schedule by Area Report
Lists total production quantities by item for each calendar day within a 14-day period for each business unit and production area. Includes number of items scheduled for completion for each day. Sort by inventory item and production due date.
Production Control, and then Define Production, and then Reports, and then Schedule by Area Report
RUN_SFS2007
SFS2008
Subcontracted PO Report
Lists purchase orders and PO numbers for subcontracted production IDs with the statuses of Firmed, Released, In Process, Pending/Complete and Complete. Sort by production start date of the subcontracted production ID, by the purchase order due date, production area, production item, purchase order number, or purchase order due date.
Production Control, and then Process Production, and then Subcontract Production, and then Subcontracted PO Report
RUN_SFS2008
SFS5001
Subcontract Components Report
Lists the production IDs and the components associated with subcontracted operations.
Production Control, and then Process Production, and then Subcontract Production, and then Subcontract Components Report
RUN_SFS5001
SFS6000
Material Picking Plan
Generates picking plan instructions for stockroom processing. Lists all items to be picked by location, component, or production ID and production schedule for a specified production start date range. Picking plan options include the PUSH or PULL method.
Production Control, and then Process Production, and then Issue Materials, and then Create Picking Plan
RUN_SFS6000
SFS8000
Genealogy Exception Report
Generate a report that lists those serial production IDs that have genealogy inconsistencies.
Production Control, and then Process Production, and then Production Genealogy, and then Genealogy Exception Report
RUN_SF_TRC001
