Production IDs Using PeopleSoft Product Configurator
The production configuration process:
Takes the detailed configuration information captured in PeopleSoft Order Management and sends requirements to PeopleSoft Manufacturing.
The production configuration rules enable you to dynamically specify component and operation list elements without having to have standard BOMs or routings for each specific configuration.
Generates configured production IDs, component lists, operation lists, and configured costs.
You can manually create a production ID for a configured item, and create the operation list and component list.
