How to Putaway Stock Using a Mobile Device
This topic lists the steps to putaway stock using a mobile device in PeopleSoft Mobile Inventory Management:
  1. Print or obtain a Material Putaway Plan Report.
    This report lists the plan ID and line numbers of the items that need to be placed into their storage locations.
  2. Putaway material (Mobile Inventory, Perform Putaway).
    1. Sign into your mobile device and select Mobile Inventory, Perform Putaway.
    2. Using the Perform Putaway page.
    3. Enter a plan ID and fetch.
    4. Using the Perform Putaway - Select page, to verify the lines of the putaway plan and to indicate that they are ready to complete.
      Use the Include check box to indicate that the location and quantity that is displayed on your mobile device is correct.
      Use the Edit link to access the Perform Putaway - Edit page to change the location, quantity, lot ID, or unit of measure (UOM).
    5. Click the OK button to return to the Perform Putaway - Select page.
    6. Click the Save button to record the putaway transaction.
  3. Run the Complete Putaway process in the PeopleSoft system (Inventory, Putaway Stock, Complete Putaway.
