Understanding Mobile Inventory Management Setup in PeopleSoft
In order to use PeopleSoft Mobile Inventory Management you must complete setup steps within your PeopleSoft environment. These steps customize PeopleSoft Mobile Inventory Management to your specific needs by setting up default values and mobile screen settings at the installation level and user level.
The following table lists the Component Interfaces used by the Fluid User Interface Architecture:
The PeopleSoft Fluid User Interface Architecture based Mobile Inventory transactions though, do not need the web services but continue to use the Component Interfaces.
| Component Interface | Description | Used by Mobile Tasks |
ADJUSTMENT_INV |
Adjustments |
Adjustments |
MIN_NONCI_TRANS |
Bin to Bin Transfers |
CART_COUNT_INV |
Get Par Locations for Mobile |
Par Count Par Count Ad Hoc |
CART_COUNT_INV |
Save Par Locations for Mobile |
COUNT_INV_CI |
Inventory Counting Event Set |
Guided Count Count By Item Count By Location |
COUNT_INV_INF |
Manual Count |
EXPRESS_ISSUE_INV_CI |
Express Issue for Mobile |
Express Issue |
MIN_FUL_INQ_INV_CI |
Fulfillment Inquiry for detail information |
Fulfillment Inquiry |
PUTAWAY_INQ_INV |
Item Stock Inquiry for Mobile |
Item Stock Inquiry |
MIN_NPO_RECV_CI |
Mobile Non-PO Receipt Service |
Receiving PO Receiving Ad Hoc |
PO_RECEIPT_CI |
Mobile Receiving Get |
Receiving PO |
MIN_PO_RECV_CI |
Mobile Receiving Save |
Receiving PO |
RECV_DELIVERY_CI |
Mobile Delivery Get |
Delivery |
RECV_DELIVERY_CI |
Mobile Delivery Save |
Delivery |
PUTAWAY_FEEDBK_MBL |
Find Stockroom Find |
Perform Putaway |
Perform Putaway Get |
Perform Putaway |
Perform Putaway Save |
Perform Putaway |
Before working with the PeopleSoft Mobile Inventory Management pages on a mobile device, you will need to define options for the PeopleTools component interfaces.
A PeopleTools component interface (CI) enables exposure of a PeopleSoft component for synchronous access from another application. Component interfaces can be used to integrate one PeopleSoft application with another PeopleSoft application or with external systems. Component interfaces execute the business logic built into the PeopleSoft component and as a result, they provide a higher level of data validation.
A PeopleTools component interface (CI) has been created for each mobile page to be used on the mobile device. The CI is linked to a PeopleSoft component within the PeopleSoft application, such as PeopleSoft Inventory or PeopleSoft Purchasing. For example, the MIN_NPO_RECV_CI has been created to interface a mobile device with the Receiving component in PeopleSoft Purchasing (Purchasing, Receipts, Add/Update Receipts).
PeopleTools component interfaces can be used to:
Find data stored in the PeopleSoft application to display on the mobile device.
Create new data in the PeopleSoft application by entering the data on the mobile device.
Modify existing data in the PeopleSoft application by updating the data on the mobile device.
Delete existing data in the PeopleSoft application using the mobile device.
See the product documentation for
PeopleTools: Component Interfaces
