Default Ship-From Values
The system may use any of the PeopleSoft Inventory business units listed in the table as the default in the Ship From field on the Order Entry Form page.
You can also use alternate sourcing to expand the ship from options and potentially source the line to new or existing supply.
See Creating Alternate Sources of Supply Arbitration Plans and Rules.
| PeopleSoft Inventory Business Unit | Description | Condition |
A |
Priority 1 Inventory business unit in the ship-to customer's distribution network. See Condition 3. |
Condition 3: This condition applies if the statements are true:
PeopleSoft Inventory business unit A becomes the default. |
B |
Highest priority Inventory business unit in the ship-to customer's distribution network that has enough product to supply the quantity ordered. See Condition 1. |
Condition 1: This condition applies if the statements are true:
PeopleSoft Inventory business unit B becomes the default. |
C |
The default Inventory business unit you selected for the Order Management business unit on the Shipping and Returns page. See Condition 6. |
Condition 6: This condition applies if the statements are true:
PeopleSoft Inventory business unit C becomes the default. The setting for the Availability Option Order Entry Features page does not apply. |
D |
The Priority 1 Inventory business unit in the default distribution network that you selected for the Order Management business unit on the Shipping and Returns page. See Condition 7. |
Condition 7: This condition applies if the statements are true:
PeopleSoft Inventory business unit D becomes the default. |
E |
Highest priority Inventory business unit in the default business unit distribution network that has enough product to supply the quantity ordered. See Condition 4. |
Condition 4: This condition applies if the statements are true:
PeopleSoft Inventory business unit E becomes the default. |
F |
The Inventory business unit that contains the product. See Condition 2 and Condition 5 |
Condition 2: This condition applies if the statements are true:
PeopleSoft Inventory business unit F becomes the default. |
Condition 5: This condition applies if the statements are true:
G |
Highest sort option source of supply from the sourcing arbitration plan that has enough product to supply the quantity ordered. See condition 8. |
Condition 8: The conditions apply if the statements are true.
PeopleSoft Inventory business Unit G becomes the default. Note: If you select Network as the Availability Option, only one PeopleSoft Inventory business unit in the distribution network returns (even if insufficient stock exists in the PeopleSoft Inventory business unit that was returned to fulfill the entire quantity requested on the order line). The system does not automatically create two separate schedules. If you use the Order Completion (OM_BACKGRND) process to process orders with electronic data interchange (EDI) as the order source, the system will not create order lines if the ship from cannot be derived. In these cases, the order status will be set to Pending. When you are in the counter sale environment, the ship from business unit defaults from the User Preferences. You can override this when adding or updating the sales order or quote. No further defaults are provided. |
Important:
If none of the conditions are met, no PeopleSoft Inventory business unit defaults are used and you cannot save the order line.
