My Work Pagelet
The My Work section of the Main tab in the Pricing Manager WorkCenter includes links to pages that you likely would need to access daily. The My Work section can also include exceptions and alerts, where you would need to take some type of action.
Some links that are set up for the My Work pagelet can be subject to filter criteria that limit the amount of data that is available to users.
If enabled by the system administrator, you can personalize your My Work section by clicking the Pagelet Settings icon.
