Understanding Sales Order and Quotation EIPs in PeopleSoft Order Management
PeopleSoft Order Management is delivered with many enterprise integration points (EIPs) to send and receive sales order and quote data from a third-party system or another PeopleSoft application. These EIPs are service operations within PeopleSoft Integration Broker.
Oracle delivers the service operations in PeopleSoft Integration Broker with a default status of Inactive. You must activate each service operation before attempting to send or receive data from a third-party source or another PeopleSoft system, such as PeopleSoft CRM. If you are using chunking for outbound service operations, the handlers must be active on the Handlers page.
Service Operation Direction and Type Handlers Chunking Available? Integrates With
PRODUCT_PRICELIST_SYNC
Outbound
Asynchronous
NA
No
Electronic data interchange (EDI), Third-party source
SALES_CRM_ORDER_CHANGE_LOAD
Inbound
Asynchronous
SalesCRMOrderChange
Load
No
Customer relationship management (CRM)
SALES_CRM_ORDER_LOAD
Inbound
Asynchronous
SalesCRMOrderLoad
No
CRM
SALES_CRM_QUOTE_LOAD
Inbound
Asynchronous
SalesCRMQuoteLoad
No
CRM
SALES_ORDER_ACKNOWLEDGEMENT (855)
EDI_TXN_855
Outbound
Asynchronous
ROUTERSENDHDLR
Yes
CRM, EDI (X12 standard format), Third-party source
SALES_ORDER_CHANGE_LOAD (860)
Inbound
Asynchronous
SalesOrderChangeLoad
No
EDI, Third-party source
SALES_ORDER_CHANGE_NOTICE (865)
Outbound
Asynchronous
ROUTERSENDHDLR
Yes
CRM, EDI, Third-party source
SALES_ORDER_LOAD (850)
EDI_TXN_850
Inbound
Asynchronous
SalesOrderLoad
No
SALES_ORDER_STATUS
Outbound
Asynchronous
ROUTERSENDHDLR
Yes
SALES_QUOTE_LOAD (840)
EDI_TXN_840
Inbound
Asynchronous
SalesQuoteLoad
No
SALES_QUOTE_NOTICE (845)
EDI_TXN_845
Outbound
Asynchronous
ROUTERSENDHDLR
Yes
These EIPs have two versions. Version 2 contains new attributes for this release.
  • Sales Quote Notice (845)
  • Sales Order Acknowledgement (855)
  • Sales Order Change Notice (865)
Integrating with PeopleSoft CRM and SCM Databases
If both PeopleSoft CRM and SCM are installed, use the Exclusions by Source Code page when running CRM Sales Order or CRM Sales Quote to exclude calculating freight, sales tax, price adjustments, or value-added tax (VAT) for sales orders or quotes when Order Completion (OM_BACKGRND) is run. Otherwise, Order Completion (OM_BACKGRND) will calculate them again.
UPC and Universal Item IDs
The Universal product code (UPC) and Universal item identifiers can be received from the various EDI transactions and are stored on the sales order, buying agreement, and RMA. A customer's ordering preference is established at the customer level on the Sold To Options page. The new options UPC and Universal Item Identifier will be available in addition to the existing System and Customer Product Identifier options.
If you use the Universal Item ID option, you can assign any valid universal item ID type to that sold to customer to be used specifically for product entry. The Electronic Commerce (OM_EC) process transforms the universal item ID that is provided on a sales order/quote inbound EDI EIP into a corresponding system product ID and unit of measure by looking for a match with IDs of the type specified on the sold to customer. If you use the UPC option, Electric Commerce (OM_EC) will transform the UPC provided on the EIP into the corresponding system product ID. The system product ID, universal item ID, and UPC will be stored on the sales order line, and the universal item ID and UPC will be available on outbound EDI EIPs such as the sales order acknowledgement, quotation notice, Advanced shipping notice (ASN), and billing invoice.
Your customers can also send user-defined fields to be stored on the sales order and sent back with the oubound EDI EIP. If any errors occur, you can correct them after running Electric Commerce using the Header (cont.) page for the custom fields.
Inbound and Outbound Process Flow Diagrams
This diagram displays the process for inbound sales orders and quote EIPs.
Inbound process flow of sales order
This diagram displays the process flow for outbound sales orders and quote EIPs.
Outbound process flow of sales order
See the product documentation for PeopleTools: Integration Broker Service Operations Monitor
