Using Lot Allocations
While entering orders, you can lot allocate a line to multiple lots or partially lot allocate the line. You can also change the lot allocations on the sales order pages, depending on the stage of fulfillment processing for the line.
This topic provides overviews of partial lot allocations and changes to lot-allocated lines and lists the pages used to use lot allocations.
To lot allocate an order line or schedule, the status must be Open. Lot allocation is performed as soon as you save the order if the Skip Lot Allocation option is not selected on the schedule or line and the Lot Allocate option is selected for the PeopleSoft Order Management Business Unit. Otherwise, you can lot allocate from the Lot Allocation component accessible from the Header menu on the Order Entry Form page.
Lot allocations cannot be performed in the counter sales environment if the customer is picking up the product unless you navigate to the Picking Feedback page.
