Viewing Product Information
View product information from the Review Product Information menu or from the Related Links button on the Product tab of the Order Entry Form page. After entering a product ID, if only one active page is accessible from the Related Links button, the page opens automatically.
You can view messages and notes associated with the product by using the Message Board. The Message Board displays the information in the left-hand frame of the sales order underneath the portal navigation.
This topic lists the pages used to view product information.
Pages Used to View Product Information
PROD_ATT
View the multimedia files attached to a product.
Messages
PROD_MSG
View messages associated with a product.
Notes
PROD_NOTE
View notes associated with a product.
Product Annotations
PROD_ANNOTE
View notes, messages, or attachments associated with the product. This link is available only when annotations are present for the product.
PeopleSoft Order to Cash Common Information: Product Definition - Definition Page
PROD_DEFN
View product details, competitor information, and product options.
Product Kit Summary Page
PRODKIT_SUMMARY
View the components of a product kit.
PeopleSoft Order to Cash Common Information: Assigning Components to Product Kits
Product Alternates
PROD_ALT
View which products, if any, can serve as substitutes for a product when it is unavailable.
