Interaction with PeopleSoft Project Costing
PeopleSoft Pay/Bill Management requires that you have PeopleSoft Project Costing installed on your system. PeopleSoft Pay/Bill Management interacts with PeopleSoft Project Costing so that you can:
Automatically create and manage projects associated with your orders.
Analyze order-related (project-related) transactions.
Process billing.
Process revenue.
PeopleSoft Pay/Bill Management automatically creates a project for each order added to the system (except for orders with a status of Draft). The system also automatically creates project owning organizations (if the Organizations feature is enabled in Project Costing), and project status records.
PeopleSoft Pay/Bill Management automatically creates a project activity for each assignment added to the system. It also adds the assigned person to the project and activity teams. For temporary assignments, the system also creates a rate set which contains the billing rates to be used for the work performed in the assignment.
Through PeopleSoft Project Costing, PeopleSoft Pay/Bill Management integrates indirectly with PeopleSoft Billing, PeopleSoft Receivables, and PeopleSoft General Ledger.
See PeopleSoft Project Costing: PeopleSoft Project Costing Integration Touchpoints
