Specifying MICR Fonts
To use the PeopleSoft Payables MICR font printing capability, make sure that the MICR fonts are loaded on the workstations. Then, the specified check lines will print correctly when you print payment forms. To make the forms machine-readable, use special magnetic toner in the laser printer. (You can order the toner from most standard toner suppliers.)
Work with your bank to make sure that the check formatting and magnetic readability are acceptable before you start printing large numbers of checks.
PeopleSoft Payables does not deliver MICR fonts.
