Approval Process for Project Approver
This topic discusses the approval process for Project Approver workflow, which includes these events:
  • Approval process event.
  • Return event.
Approval Process Description
Information Type Description
Event Description
This event is triggered when a user clicks the Submit button on the Project Request page (BC_PROJ_REQUEST1).
Action Description
The system sends a worklist item to the individual who is identified in the Approver field on the Project Request page (BC_PROJ_REQUEST1) and changes the project request status to Submitted.
Notification Method
Worklist
Approval Process Workflow Objects
Event
APPROVAL_PROCESS
Approval Rule Set
PPK_PROJ_APPROVAL
Business Process
PPK_PROJ_APPR_BP
Activity
PPK_PRJ_APPROVE_ACTIVITY
Role
SUPERVISOR, MANAGER, VICE_PRESIDENT
Return Description
Event Description
This event is triggered when a the approver clicks the Return button on the Project Request Approval page (BC_PROJ_REQUEST1).
Action Description
The system sends a worklist item to the individual who is identified in the Requester field on the Project Request page (BC_PROJ_REQUEST1) and changes the project request status to Returned.
Notification Method
Worklist
Return Workflow Objects
Event
RETURN_EVEN
Approval Rule Set
PPK_PROJ_APPROVAL
Business Process
PPK_PROJ_APPR_BP
Activity
Role
