Integration with PeopleSoft Resource Management
PeopleSoft Resource Management is not required for implementing PeopleSoft Program Management. When integrated with the program management system, PeopleSoft Resource Management enables project managers to:
Search for qualified candidates to fulfill resource requirements.
Assign and schedule resources.
Create service orders to fulfill requirements for a project team.
To schedule labor resources for projects, access the Resources page and select the Committed status for the Resource Status field for that resource.
If the dates of the resource conflict with an existing calendar entry, the system displays a message and you can either remove the resource from the Resources page or override the conflict and book the resource.
Resources are booked in PeopleSoft Resource Management based on the resource availability dates that are on the Resource Detail page. The Resource Detail page allows the resource to be scheduled for multiple discontinuous date ranges.
