Related Product Documentation
The PeopleSoft Program Management documentation provides you with implementation and processing information for your PeopleSoft Program Management system. However, additional, essential information describing the setup and design of your system resides in companion documentation. The companion documentation consists of important topics that apply to many or all PeopleSoft Enterprise applications across the Financial Management Solutions, Enterprise Service Automation, and Supply Chain Management product lines. You should be familiar with the contents of this documentation.
The following companion documentation applies specifically to PeopleSoft Program Management:
PeopleSoft Application Fundamentals
Setting Up PeopleSoft Global Options and Reports
PeopleSoft Project Costing
PeopleSoft Resource Management
