Adding Projects to Trees
There are two ways to add a project to a tree:
Create the project using the Project General component (PROJECT_GENERAL) and click the Project Tree link in the Project Costing Definition page to insert the project as a node on a tree.
If you branch a tree, you cannot add a project to the branch from the Project Costing Definition page.
In PeopleSoft Tree Manager, select the node to which you want to add an existing project, and click the appropriate icon to insert the project as either a sibling node or a child node.
Use the Tree Manager component (PSTREEMGR) advanced search page to look for trees with a category of PROJECT.
If there is not a level defined below the parent level, PeopleSoft Tree Manager creates the next level automatically when adding a child project. The newly created level, however, will not have a name or description.
Pages Used to Add Projects to Trees
| Page Name | Definition Name | Usage |
Assign to Project Tree Page |
PC_PROJ_TREE_SEC |
Assign a project to a specific tree. To access this page, click the Project Tree link in the Project Costing Definition Page. |
Tree Manager |
PSTREEMGR |
Insert, delete, or rearrange projects on a project tree. See PeopleTools: PeopleSoft Tree Manager |
Related Topics
