Analysis Groups
You use analysis groups to:
  • Analyze projects
  • Map analysis types
  • Enhance system performance
Many analysis groups are necessary for Project Costing project analysis functions and mass changes to execute properly. If you choose not to use the analysis groups that are delivered with Project Costing, you still have to configure the analysis groups or create new ones to use with these functions. This table describes the analysis groups:
Analysis Group Description
ACT
Actual Cost
ADJST
PC (Project Costing) Transaction Adjustment
ALL
All Analysis Types
AMCOR
Project Costing to Asset Management Cost of Removal
AMPFS
Project Costing to Asset Management Proceeds from Sale
AR
Receivables
BFEE
Billing Fee
BI
Billing
BLD
Billed Transactions - Worksheet to Project Transaction table
BUD
Budgets
CBU
Cost Sharing Budget
CLOSE
Project Costing to Asset Management Asset Summary
COM
Commitments
COPY
Template Copy
COSTS
Estimated and Actual Costs
CRQ
Cost Sharing Requisition
CSCOM
Cost Share Commitment Balance
CSTSH
Cost Sharing Analysis Group
EAC
Estimate at Completion
FNA
Facilities and Administration
FOR2C
Forecast Cost at Completion
FREV
Forecast Revenue
GBUD
Grants Budgets
GL
General Ledger Analysis Types
GMACT
Grant Reporting Actual Expense
HBPV1 through HBPV4
Historical Budget Version 1 through Historical Budget Version 4
INT
Interest Calculation
LABOR
Labor Cost and Time
MMCST
Maintenance Management Costs
OPENC
Open Commitment Balance
PCADJ
Project Costing to Asset Management Profile Adjustment
PCBUD
All Projects Budget Types
PMBIL
Mgr Trans Review (Manager Transaction Review) - Billing
PMCST
Mgr Trans Review - Cost
PMEXP
Proposal Management - Expense
PMPOP
Mgr Trans Review – Period of Performance
PMREV
Mgr Trans Review - Revenue
PMSHR
Mgr Trans Review - Sharing
PMTIM
Proposal Management - Time
POADJ
Purchasing Adjustments
PRECL
Project Costing to Asset Management Profile Summary
PSBLD
Billing to Project Costing
PSCST
Accounting Costs
PSDEF
Funds Distribution Defaults
PSDST
Funds Distribution
PSECC
Estimated Costs to Completion
PSITD
Inception to Date Costs
PSLMT
Limit Processing - Billing
PSREV
System Revenue
PSROL
Limit Processing - Revenue
PSRV2
GC (Government Contracting) System Revenue
PSTDR
Sharing
PSUAB
Revenue on Unapproved Billing.
Analysis types included in this group and the PSREV group are eligible for revenue recognition prior to being reviewed or approved for billing.
PSVP
If using variance pricing, use this analysis group to map a converted analysis type to its original analysis type during the Variance Pricing process (PC_VAR_PRICE). As a transaction progresses through the billing process, the analysis type is changed. For example, a BIL analysis type is changed to BLD when the transaction is invoiced in PeopleSoft Billing.
This can cause issues when trying to net new pricing rows with historic rows. Therefore, in the example, this analysis group assists the Variance Pricing process to map the BLD transaction row to the BIL transaction row.
You can modify this analysis group.
PSVPX
If using variance pricing, use this analysis group to prevent analysis types from being included in historical rows. For example, a sales tax row that is generated in Billing may be considered to be outside the contractual rate. This transaction carries the original resource from ID, and would normally have been included in the netting process and the historical rows.
PSWKS
Billing Worksheet Grouping
RBUD
Revenue Budget Group
REQ
Requisitions
RFEE
Revenue Fee
SPACT
Grants Sponsor Actual Costs
SPENC
Grants Sponsor Commitments
UNBLD
Unbilled Transactions
VARY
Variance
Using Analysis Groups to Analyze Project Costs
You use analysis groups to define relationships among analysis types to analyze project costs using Project Costing pages, queries, or reports.
Creating an analysis group to analyze projects follows this process:
  1. Group the analysis types to include in the project analysis.
  2. Apply the appropriate multiplier to each analysis type to create a relationship.
A multiplier determines how amounts and quantities for a specific analysis type are factored into the analysis. The multiplier is applied to total quantities and amounts in all transactions identified by a specific analysis type. For example, to add amounts to the analysis, enter 1. To subtract costs from the analysis, enter −1. To add half of the amounts to the analysis, enter 0.5.
The easiest way to create analysis groups for analyzing projects is to start with an equation. An equation makes it easier to determine what multiplier to assign to an analysis type. For instance, to create an analysis group to determine whether or not a project is over budget, you might start with this equation: Budgets − Actuals = Budget-to-Cost Variance.
You assign a multiplier of −1 to the Actual Cost analysis type and a multiplier of 1 to the Total Cost Budget analysis type. When using this analysis group for online analysis or reporting, all actual costs from the analyzed project are subtracted from budgeted costs. If the result is a negative number, the project is over budget. To set up the analysis group so that a positive number means that the project is over budget, reverse the multipliers so that budgeted amounts are subtracted from actual costs.
You can apply multipliers to quantities for each analysis type included in an analysis group. When you create analysis groups to analyze project costs, multipliers will probably be the same for both the amount and the quantity.
Using Analysis Groups to Map Analysis Types
New projects or activities can be created from copies of existing projects and activities. You can specify an analysis group to map analysis types from the existing project or activity to the new project or activity. For example, when you create a new project from an existing project, you can create an analysis group that maps actual (ACT) transactions from the existing project to the newly created project as budget (BUD) transactions. By using analysis groups, you can also manipulate mapped amounts. For example, you can enter a multiplier of 2 to double the budgeted quantities and amounts in the new project.
Using Analysis Groups to Enhance System Performance
On some PeopleSoft Project Costing pages, analysis groups limit the number of resource transactions that appear on a page at one time. For example, when there are tens of thousands of transactions per project in the system, performance is greatly reduced if you try to access all of those transactions every time that you open a page. By using analysis groups, you can limit the number of transactions that appear on a page to transactions of specified analysis types.
To do this, create an analysis group that identifies a group of analysis types. When an analysis group is entered as part of the selection criteria, only the resource transactions that contain the analysis types specified in that analysis group are available for use on the page.
