Project Costing-Contracts Interface Process (BIPCC000)
Run the Project Costing-Contracts Interface process after you run the Billing Finalization process. The Project Costing-Contracts process updates the Contracts-Billing Cross-reference table and the Project Transaction table with the finalized bill information from PeopleSoft Billing.
Rate-based row amounts are subject to change throughout the billing process. For this reason, the system sends the rate-based rows and their final invoice amounts to the Contracts-Billing Cross-reference table only when you run the Project Costing-Contracts Interface process.
All rate-based rows and their associated discounts and retainages are written to the Project Transaction Temporary Billing table. The process includes rows with these analysis types:
  • Billing adjustment (BAJ)
  • Billable amount (BIL)
  • Billing retainage (BRT)
  • Billing discount (DSC)
  • Released retainage adjustment (RAJ)
  • Released billing retainage (RRT)
The Contracts-Billing Interface process inserts fixed-amount bill rows into the Contracts-Billing Cross-reference table. This is because fixed-amount rows are not modifiable; you can only accept or delete them. The system updates the bill row status throughout the Billing Interface process, worksheet cancellation or acceptance, and the Billing Finalization process. Fixed-amount rows that specify a project are sent to PeopleSoft Project Costing with an analysis type of FBD (fixed cost billed amount).
The PeopleSoft Billing: Running the Billing to Project Costing/Contracts Interface Process (BIPCC000) topic discusses the fields that the Billing Finalization process updates in PeopleSoft Contracts.
Although only certain project activities pertain to particular contract lines, the system does not store project activities in the Contracts-Billing Cross-reference table. Activities are summarized by project and billing currency.
