Rate Options for Labor Costs
To price transactions by using the cost and bill rates that are defined on the work order task, use the rate options of WCO (work order labor cost rate) and WBI (work order labor bill rate). By using the WBI and WCO rate options, you instruct the Pricing Application Engine process (PC_PRICING) to retrieve cost and billing rates from the work order labor rate to calculate the target amount.
