Setting Up the PeopleSoft Fluid Projects WorkCenter
This topic discusses the setup for the PeopleSoft Fluid Projects WorkCenter.
PeopleTools 8.55 is required for the PeopleSoft Fluid WorkCenters.
To personalize the PeopleSoft Fluid Projects WorkCenter, see Application Fundamentals: Setting Up and Personalizing PeopleSoft Fluid WorkCenters.
